How to identify the source of a suspension air leak?
Hi All,
I have a 2003 Allroad and I believe that I have a leak in the air suspension. However, I'm not exactly sure where the leak is, and I'm hoping the audi ninjas in this forum can help me out
Below is a description of the symptoms.
1) Currently the front of my audi is setting at level 1 or lower. When I turn the vehicle on, the level 1 light begins to flash and I think that the airbag is trying to fill up. However, after a little while, the light stops blinking and when I push the "level up" button, nothing happens. If I turn the vehicle off and then start it again, the level 1 light will blink and try to fill up the bag again.
2) From time to time the front air suspension will raise and will hold at level 2 or 3 for 1/2 a day before the front end lowers again to level 1 or lower, and then repeat the symptoms mentioned above.
3) When I turn the car on, I can hear the air compressor in the rear trying to inflate the bags. However, I can't hear an air compressor in the front (and I'm not sure if there is a compressor in the front) turn on.
Based on this information, do you think that the leak is in the bag, the lines, or do you think the air compressor needs to be rebuilt/replaced? Is there a process that I can go through to determine where the leak is/ which parts need to be replaced?
Thanks for any help you can offer, it is sincerely appreciated!
Pat
Pat
There's only one compressor, and it's in the rear.
Spray soapy water on the air springs and look for bubbles. It should be quite obvious where the leak is using this method. Buy aftermarket air springs from Arnott.
You likely also have a tired compressor if it's been working hard trying to fill up a leaky air spring. You can buy a rebuild kit for the air spring on ebay for around $50 and make it good as new. The rebuild kit supplies a new plastic piston ring that should improve the performance of the compressor.
Be sure to spray the soapy water with the suspension at level 1 as this is the most common level that a leak shows itself. You may need to remove the wheel and then jack up the hub to load the suspension and compress the air spring.
Like was said above your compressor is likely worn out and needs to be rebuilt. Not a hard job at all.
Here's my DIY compressor rebuild thread: https://www.audiworld.com/forums/sho...ressor+rebuild
Thanks for the advice sb_gli & G0to60. I'll pop off my wheels this weekend and try to identify the location of the leak. I was thinking about rebuilding the compressor, and after your advice I'll definitely be purchasing the rebuild kit.
One quick question. When the Allroad is started, does it try to fill all the suspension bags at once, or does it fill the rear first, then the front, or vise versa?
Thanks!
Thanks!
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
Pmpsch
Q7 MKII Discussion
14
12-06-2015 01:14 PM
ECS Tuning-Audi
09-03-2015 12:45 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
