If a suspension warning light registers does it store a code, and if so, does that code self-clear?
AudiWorld Expert
We took our POS in again for the suspension intermittently drooping and not coming back up (which when it happened would register the warning light) and the morons at the dealer can't find anything wrong.
AudiWorld Uber User
Not always
if the car droops when it's off and the suspension comes back to normal quickly when parked, then no it won't record a fault.
generally if its an electronic problem a fault is stored...but...
an air leak in th springs or lines or distribution block won't issue a code if the car can be leveled.(your case).
The dealer needs to see it down and you have to say..where did the air go?
Jean Veego
Suspension Tuning Discussion
11-20-2018 05:34 PM
Audivision
VAG-COM Discussion
10-01-2004 02:01 PM
