intermittent temp gauge...
Started on Friday night... cruising along with the usual 12 o'clock position and then slowly drops to C. then inexplicably climbs slowly back to normal.
Sender? Moisture in a wire harness? Is the allroad going through menopause?
Re: intermittent temp gauge...
I had a 99 A6 that would do that. I never did find out what the issue was before I traded it for the AR. However, I would just watch the oil temp closely to make sure it didn't raise unexpectantly.
not speed dependent. Just likes to meander
I want to repair whatever the fault is... I guess I can break out the bentley but I was being lazy and wanted someone to chime in with "it's Fitzer value bearings" or something.
