need help with timing
Old Jan 25, 2011 | 09:23 PM
04allrodeo's Avatar
Default need help with timing
my crank shaft moved while i was changing my timing belt... what do i do? just turn it back ?
Old Jan 27, 2011 | 08:24 AM
swamper8's Avatar
There's a crank alignment hole/pin on this motor. It's at the back/driverside of the engine. First pull the plug out and shine a light in the hole. You'll want to have a buddy turn the crank by hand until you see the hole in the crank line up with the hole in the block. They make a locking pin/tool which goes in here when you're doing major engine work to prevent the crank from turning. Too late now but it's cheap insurance. Better to have turned your crank than to have turned any of the cam shafts.
Don't be too aggressive turning the crank. If there's resistance stop as the piston may be contacting a valve.
http://cgi.ebay.com/ebaymotors/VW-AU...motiveQ5fTools
ourv12
Dec 7, 2010 05:40 PM
crew219
12
Mar 11, 2006 06:08 PM
boostedte37
Jun 27, 2005 04:44 AM
Audi-Impaired
Jul 8, 2002 04:41 AM
Kjelle
Audi 100 / A6 (C4 Platform)
Feb 5, 2002 09:07 AM
