new driver front level sensor Q's
Likely you may need to calibrate the new sensor, may have to do adaptation. Essentially, just like the 402 mod except without altering vehicle height.
I've been wrong before and could be wrong here, but I'm aware that strange things have happened to air suspension systems readjusting to their proper level on not just allroads but a host of other air suspension equipped vehicles after suspension worked was preformed without taking into account this issue. Pretty sure there are threads here regarding it.
Now, about the level sensors: just like all other Audi's with these devices, the parts are mechanically mounted to the car and there is no adjustment. When the car is lowered back down to the ground the sensor will detect it's position and make any necessary adjustment to level the car. In other Audi's with these things the adjustment will be to headlamp level only.
To be perfectly clear, install it and forget it.
JMO.
JMO.
Would it be possible for you to mail it over once you swap the new sensor in? I will naturally cover the mailing cost.
