O2 Sensors & Error Codes
Is Bank 2 pre-cat and Bank 1 post-cat?
Is Sensor 1 driver's side and Sensor 2 passenger side?
Error messages are:
P0155 - Heater malfunction (Bank 2 Sensor 1)
P0135 - Heater malfunction (Bank 1 Sensor 1)
Thanks!
Chris
Sensor one it the front sensor 2 is the rear.
In both cases your front 02 sensors are showing a code. Clear them and see if they both return.
Sensor 1 is Pre-Cat (front)
Sensor 2 is Post-Cat (rear)
Bank 1 is Driver's side
Bank 2 is Pass side
They do return and I've already bought the O2 sensors. Need to replace in order to pass DEQ here in Oregon.
Thanks for the info.
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
My logic says that the pre-cat O2 sensor on the passenger side is failing, but I want to confirm this is the case before purchasing a new one.
