Oil lines that runs into the radiator, what is it for?
Old 08-19-2007, 06:04 PM
sugaryling's Avatar
Default Oil lines that runs into the radiator, what is it for?
While replacing the radiator, I had to remove 2 oil lines that run into the radiator. Both on the passenger side of the radiator. What are these lines for? Messed the lower one up and need to replace it.
Old 08-19-2007, 06:13 PM
Trango's Avatar
On my 6MT, they are tranny cooler lines.
Old 08-19-2007, 06:16 PM
sugaryling's Avatar
I have a TIP, same thing?
Old 08-19-2007, 06:36 PM
want's Avatar
Yes.
Old 08-19-2007, 06:37 PM
Senior Member
allroad'Ed now's Avatar
Default They are your Tip trans lines. The trans is cooled through the radiator
If you messed one up, get it replaced before you drive it. If you've pinched the line you could restrict the flow of fluid to the trans.
chessie254
02-27-2009 03:10 AM
Lauda81
08-05-2008 03:04 AM
Pinoy Rider
12-28-2006 06:03 AM
GlasSman
08-03-2004 05:57 PM
lizziedickerson
08-26-2003 04:38 PM
Quick Reply: Oil lines that runs into the radiator, what is it for?
