What are the options of a turbo leaking oil?
It just showed up and hasn't affected driving performance at all. Can things be saved? I don't know much about the turbo system. Any advice would be appreciated.
We had a "turbo leak". Had an independent shop tell us the turbo was starting to leak and the dealer. The car was a CPO, so I was hoping to get it covered under warranty, but it wasn't meeting the correct "class/stage" leak. Took it in to the dealer another time and they found out it wasn't the turbo, but the turbo return lines. Much less cost to fix.
OK, so the details are that the seal on the turbo is developing a leak. Turbo itself is fine, but they recommended replacing it since it has 108k miles on it. So it is either rebuild kit or new turbo, and labor to pull the engine.
Does that sound about right to you all?
Turbo's
I am dealing with the exact same situation on my AR 02". Local mechanic or Indie Shop says it's the turbo's. We still have a CPO warranty(? 3rd party warranty) that covers them till 85K and were at 83K. The warranty place says that it's not at the critical stage where the turbo's need replacing.
Thoughts? The warranty place will now not return our calls, as the mechanic has taken pictures and insist that it's the turbo's going bad, and has pics of the oil leaking on the floor as he diagnosed the problem when he was repalcing the timing belt on the 80K maintenance.
as others have said, more often than not the source of the leaking oil is not from the turbo itself.
however if you've already determined that it is indeed the turbo, your options would be replacement (if under warranty), or a rebuild. obviously if you don't have a warranty, all of the options would be pricey.
good luck
good luck
If the oil is leaking from the internal packing its a problem.
If the oil is leaking from the seal on the feed or return line, just fix that lin'e seal. No worries. (BTDT)
As far as aftermarket warranty, perhaps you can get a second opinion from another shop and document it with photos.
Then call your state's department of insurance and ask them for help.
edit
IIRC...yes. Unscrew the line, take out the seal, etc. You need someone who has been there...ask for Ex-PzKW Cdr or
Autosolutions on the allroad forum of quattroworld.com
They are both techs and know first hand.
