Which charging strength - 50% or 100%?
Old 02-02-2020, 10:34 AM
suttoni's Avatar
Default Which charging strength - 50% or 100%?
I have a dedicated 240 volt outlet in my garage. I have been charging at the 100% setting on the control unit. Now I see that the blades on the charging cable plug are starting to corrode and lose their plating. I have to apply Super Lube to the blades just to insert and remove the plug. Does this only happen at the 100%?
Old 02-02-2020, 06:01 PM
skaven81's Avatar
That doesn't sound right at all. I would take your e-tron and charger to the dealership to have them check it out. The charging plug should be good for thousands of charge cycles without requiring any maintenance.
Old 02-02-2020, 07:17 PM
Tronification's Avatar
Sounds like you might be removing and re-inserting the plug a lot. With the rated amperage, it needs to be very tight to prevent overheating and potential fires, and a lot of such insertions/removals can be tedious and can wear down the prongs.
If you are indeed removing your EVSE often, consider getting a secondary one to leave permanently connected and keep the OEM one in the car.
e-tronDriver (02-03-2020)
Old 02-02-2020, 07:26 PM
Mike in CA's Avatar
^ Good advice.
Old 02-05-2020, 07:33 PM
lkfoster's Avatar
All that I'd consider using is a dielectric grease like this or similar.
https://www.oreillyauto.com/detail/b.../4776639?pos=2
No petroleum-based lubricants.
Old 02-06-2020, 04:00 PM
suttoni's Avatar
Originally Posted by lkfoster
All that I'd consider using is a dielectric grease ....No petroleum-based lubricants.
Super Lube is dielectric.
I'm only recharging once a week.
Still wondering what the practical difference is between the 50% and 100% charge rate?
Old 02-06-2020, 04:59 PM
Mike in CA's Avatar
Uhh...you can charge twice as fast at 100%. That's not a trick question is it?
Old 02-06-2020, 05:33 PM
WetEV's Avatar
If you arrive at a RV park, and if there is a sign saying "don't draw more than 30 Amps or you will pop the breaker", then set to 50%. I've seen such a sign.
Old 02-06-2020, 10:04 PM
suttoni's Avatar
No, I don't do trick questions. The answer was posted above, thanks.
Old 02-06-2020, 11:48 PM
The energy wasted as heat throughout the circuit, both external and internal to the battery, is proportional to the square of the current intensity (amperage).
Twice the current = 4 times the energy loss and generated heat. That’s both less efficient and more dangerous, should you have subpar wiring. It may also impact the battery life to a greater extent than charging at a lower power (unclear if that’s material at the respective power level).
As long as you draw current above whatever threshold is required by the battery chemistry, a level which would also give you a full charge in a reasonable amount of time, the lower the amps the better.
The following 2 users liked this post by Tronification:
RAudi Driver (10-12-2022), SonnyUte (01-07-2022)
Quick Reply: Which charging strength - 50% or 100%?
