Tire wear '19 -'20 e-tron?
I don't think I'm on track for 40,000 miles...but only because of edge wear on the fronts. I haven't measured it but the majority of the treads are still well away from the wear indicator strips
I'm thinking maybe they didn't do such a great alignment job for me at the dealer.
I sure do wish I knew of a place with an real alignment guru....
A rotation would likely have minimized the cupping or at least spread it between the front and rear tires.
Trying to determine if these 1st/2nd generation e-trons have any particular tendency for edge wear or anything else
and I suppose related to that might be tire brand/model, etc....
How many folks have seen very even wear vs uneven....?
and for those seeing uneven wear do you have an explanation for it.... sporty high speed cornering, known maintenance issue, etc....?
And are some of the tire brand/models tending to wear noticeably better than others?
If Goodyear added a bit more meat to the outer tread blocks, this would be a nonissue, but that would likely come at the expense of less crisp handling. In retrospect, I’d say the current design is a decent compromise.
Overall the Goodyears are fine, but had I been able to choose, I would have moved to a different brand. I tend to prefer Michelin, but not sure they make an electric car tire.
I'm pretty sure the dealer short-cutted my 10k and 20k service intervals and skipped the rotation
I'm conflicted about it but mostly ok with it. Seems like whenever someone removes a wheel, they bend it and the car shimmies from that point on.... I'm happy to keep this car smooth like butter as long as possible
Art234, did you happen to notice hat sort of wear patterns you had at 39,000? very even? a little more on the edges?
