95.5 S6 Windshield Washer Pump Replacement
So I am trying to replace my windshield washer pump, i believe that is the reason my washers do no work.
I pulled the inner fender lining out with hopes to get to the pump. It turns out the air conditioning drier/reciever is in the way, preventing access to the washer pump.
What is the correct procedure for replacing this pump? Could it just be a blown fuse or relay? I couldnt find a fuse or relayfor the washer pump, so i assumed it is the pump.
Thanks guys,
Alex
Thanks guys,
Alex
If you can't see the pump(s) with the liner off. You will have to pull the tank up and out.
PN for the pump is 4A0955651B. Fuse is No. 13 (see below)
Price varies with quality: https://www.ecstuning.com/Search/SiteSearch/4A0955651B/
nagelandy55
11-14-2010 06:27 PM
