Brake issues
Brake issues
My '93 S4, which I had given to my daughter, had the brakes stop working. Seems to be a little boost on first application, but pedal very hard, stoping slowly with great pressure. Slight vibration in the pedal. Worked it hard, all 4 discs warm. I did the requisite sta, good info on replacing the various parts, but not for diagnoses. I suspect the bomb, but shouldn't the system have pressure when the engine is running? Could it be plugged, it's been years since a fluid flush. Brake indicator is on, power steering is fine. Any thoughts would be greatly appreciated, I'd like to keep the old girl alive, she's been very good to me.
Search for a test on the bomb, i.e. how many pumps with the engine off until the pedal gets real hard. From the SJM Autotecknik website:
"One test for the accumulator, is to run the engine for a few minutes, turn off the engine, and then pump the brake pedal until the pedal feels hard, (no more power assist). Normally with a good, working brake accumulator, this test takes 25-35 pumps on the pedal before the pedal gets hard. If the pedal gets hard with only a few pumps on the pedal, the brake accumulator is defective and should be replaced. "
SJM Autotechnik, Audi Technical Service Repair Information
Brake issues
Replacement: HERE
Rebuild: http://12v.org/urs/GrahamTsPSPBPumpStripDownDIY.pdf
Brake issues
I think it is the bomb (pressure accumulator for you readers from Home Land Security). However, *IF* it isn't the bomb then it is the one side of the tandem power steering/power brake pump and you either need to replace it or rebuild it.
Replacement: HERE Note: the photos have been temporarily lost due to the vBulletin rocket surgeons here at Audiworld who stupidly and arbitrarily changed photoposter account numbers, killing thousands of photo links and gutting hundreds of DIY posts - idiots.
ISOTORQUE DIFF
11
09-23-2009 12:11 PM
audiqtNewb
10
01-16-2007 06:27 PM
Kirath ¾-B0§t0n
12-03-2003 02:42 PM
