Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
How many hours of labor for a "good" shop to install clutch/flywheel?
Old 11-19-2007, 03:07 PM
UR-Idiot Savant-S6's Avatar
Old 11-19-2007, 03:31 PM
tpierce's Avatar
Default i thought the book time was around 9 hours
you haveing clutch problems?
Old 11-19-2007, 03:54 PM
Default Yikes...........no problems currently but with the other "changes".......
I'm putting in a JB Racing 10.5 lb flywheel and Southbend FW Clutch to get power to the ground. Oh well...........what's another $800?? God bless my wife.
Old 11-19-2007, 04:28 PM
TabulaRasa's Avatar
Default It took my indy mechanic 24 hours (saga)
He charged me $750 labor + $100 for resurfacing the flywheel. I provided all my own parts which I bought from various sources online.
He'd never worked on a urS6 before, but he did work on B5/6 A4 and B5 S4's and he does specialize in just Audi's. His personal car is a Stage I B5 S4.
I got a new clutch, resurfaced flywheel, t/o bearing, front diff oil, new front diff seals, new rear main seal new clutch slave.
Also installed the timing belt, front crank seal, front cam seal, water pump, serp belt, and idler pully at the same time for an extra $300.
Here was the plan: Day 1, car on lift, drop the trans, send out flywheel for resurfacing. Day 2, reassemble, reinstall, done!
Here's what really happened:
Day 1. Trans was out of the car in about 2 hours. I watched the whole thing. Impressive. The flywheel was bagged and sent out with a courier to the flywheel shop--still warm.
Day 2 went well until trying to get the clutch slave in, he stayed up till about 1 am trying to finish the car up but the clutch slave was a real biatch till he called it a night. I know he wasn't bull****ting me cause I was in the shop till about 10pm myself watching (he didn't mind, and I had no other transportation...)
Day 3. Car is finally back together around 6pm. I pay and drive away. 9k miles later and everything is working great.
If you're in the Minneapolis/St. Paul area I would highly reccomend this guy. (no it's not Anderson Motorsport)
Here are his rates, I think they are very fair (parts not included)
Engine
Clutch S4 $750
A4 $700
Cat Back Exhaust A4, S4 $50
DTS Stabilizer Bar A4, S4 $60
Downpipes (S4) S4 $250
Downpipe-catback(1.8/2.0) A4 $150
primary O2 sensor replacement(P) S4 $60
primary O2 sensor replacement(D) S4 $85
EGT replacement(P) S4 $50
EGT replacement(D) S4 $75
Fuel Filter A4, S4 $50
($75 total with part)
Suspension
CV Replace A4, S4 $100/shaft
Swaybars A4, S4 $75/set
Shocks/springs* A4, S4, TT, R32 $350
*(Seized upper control arm bolts add $50 per seized bolt)
Bearing (rear) A4, S4 $120
Bearing (front) A4, S4 $150
Brakes (pad/rotor replace) A4, S4 $75/pair
Old 11-19-2007, 04:40 PM
Default Thanks for the info.........
I'm pretty lucky and have 2 very well known Audi shops within 10 miles of me here in NJ. KMD tuning and Quattrohaus. I'm going to price both. I'd probably never go the direction I'm going in without them nearby as I'm getting out of my skill set now.
Old 11-19-2007, 05:31 PM
kday's Avatar
Default That slave is a bitch. I wonder if he had the same issue I did...
Which is: do NOT connect the hydraulic line before bolting the slave in. It seems like a good idea (the fitting is hard to get to, you'll keep brake fluid out of your eye, etc.) but it's REALLY hard to get the piston compressed while aligning it when the line is attached.
I spent hours and hours on that too.
Old 11-19-2007, 05:32 PM
kday's Avatar
Default Don't be a wimp... DIY.
<img src="http://www.boost-instruments.com/clutch/sDSCN0837.JPG">
Old 11-19-2007, 05:38 PM
tpierce's Avatar
Default it's not that fun of a job while the car is on a lift
i cannot imagine doing it on the ground.
Old 11-19-2007, 05:51 PM
Zwoobah's Avatar
Default that picture does not give you a good idea of the space constraints in kevin's garage
i doubt that he could fully open either door of the S4. i'm still in awe.
Old 11-19-2007, 07:00 PM
bartzgs's Avatar
ktan? or collins?
Quick Reply: How many hours of labor for a "good" shop to install clutch/flywheel?
