Thermostat Question?
I saw somewhere a while back that the coolant temperature fully wamred up should be almost straight up. Mine only goes a bit past the first mark after it leave the bottom. I would guess at about the 10:30 location.
If this is true, I will change the thermistat. I just want someone elses input.
Thanks,
James Shackelford
Thanks,
James Shackelford
Re: Mine used to run even cooler than that, new thermo fixed it.
My '96 2.8L is slow to warm up and cools off on the highway, likely the thermistat? Also what is normal oil temp. for these engines? Is the thermistat buried in the back by the firewall?
BSCA4
10-03-2005 10:04 AM
