top speed limiter?
top speed limiter?
when I removed my ecu to send it off, I removed my top speed limiter (sp?) at the same time as the site I was looking at gave directions on the quick and easy (unplug this) directions. I was fairly certain it was on urs4.com. I went over there and that part isn't in the directions. (it has been 6 months or so, so I'm just not certain it was there that I saw that)
My brother just purchased a 93-s4 and sent his ecu off for a MTM and was asking where he disconnects the limiter. I drew a blank. Any help on where to find it, or rather what the connection looks like so I can direct him?
I will post on s4 forum as well due to time constraints.
Thanks much
Thanks much
Top Speed Limiter removal procedure with photos...
<center><img src="http://www.urs4.com/technical/engine/topspeed/DSCN0146_small.JPG"></center><p>Sorry, but those pages didn't make it back on the site after the last redesign. So, I ran home at lunch, reformatted them, and reposted them. They still need a bit of design work, since I doubt anyone really needs poster sized photos of this procedure, but anyhoo...
From Urs4.com, drill down through: Technical | Engine | Top Speed Control Module
Or, just go to the link below.
(There is also a link to the ECU removal procedure, which you will need to do this.)<ul><li><a href="http://www.urs4.com/technical/engine/topspeed/topspeed.html">Top Speed Control Module Removal Procedure</a></li></ul>
NCFioren
04-14-2002 04:59 PM
