New Product - R8 Gen2 Programmable CETE Exhaust Valve Controller...
Audiworld Basic Sponsor
A little extra flexibility and programmability has come to the already popular CETE exhaust valve controller...
Information:
With this exhaust valve control module you have the ability to better control your exhaust valves and program their behavior via a smartphone app. The controller allows you to program exactly how you would like the exhaust valves to behave in specific drive select modes. The exhaust valves will also automatically be set to the last drive select setting upon startup. The safety RPM for the valves opening can be set to the user specific setting. The factory control button that is double tapped to turn the module on and off completely can be programmed to be the ESP or Auto Start/Stop (if applicable). The full drive select system stays intact and functional, plus no added key fobs or controls are needed. Works with all models that have factory or aftermarket exhausts with valving that are utilizing the factory control systems.
Questions, Quotes:
If you have any questions or needs other than those posted above please don't hesitate to PM/email: contact@europrice.us
Cheers!
- - Complete Control of Exhaust Valves with Factory Controls
- - No Additional Key Fobs Required for Full Control
- - Updated Intuitive and Simple to Use App
- - Bluetooth Connection to App makes for Easy Use
- - Valves can be Opened and Closed via App
- - Plug In - Tapping of Two Wires is Required
- - User Programmable - Fully Open Valves or Speed Sensitive
- - User Programmable - Fully Closed Valves until User Specific RPM
- - Dynamic and Comfort - Steering Wheel Satellite Control Inactive
- - Automatic and Module Off - Steering Wheel Satellite Control Active
- - Startup - Valves Revert to Last Setting Used on Shutdown
- - Programmable ESP or SSA Double Tap - Turns Module On/Off Immediately
Information:
Questions, Quotes:
Cheers!
Alex@Europrice.us
S4 (B9 Platform) Discussion
9
03-04-2019 10:14 AM
Alex@Europrice.us
Audi A3 / S3 / RS 3 MKII
02-25-2019 10:51 AM
Alex@Europrice.us
S6 (C7 Platform) Discussion
02-19-2019 11:35 AM
Alex@Europrice.us
02-19-2019 11:34 AM
Alex@Europrice.us
TT (Mk3) Discussion
02-19-2019 11:32 AM
