Removal of holograms and swirls
#11
Ok guys. I know I'm hijacking this thread but I didn't want to create a new one and ending up in too many threads for the same problem.
I bought a new A4 a month and a half back. I've washed her thrice at the local automatic car wash since it's too cold to hand wash her at my house.
I've now noticed a few swirls (visible when light falls on it) on the hood caused by the tags on the microfiber I used to wipe off the remaining water. There are other minor swirls which only I can see (and obviously other detailers/petrolheads too) which I'm planning on getting corrected once winter is over and I get her detailed properly. I'll be hand washing her after she is detailed.
Now my problem is that these few swirls are giving me sleepless nights since that's the first thing I see. I don't have any sort of detailing apparatus or products with my. Is there any swirl remover that I can use by hand to get rid of these swirls? I'm not keen on using a machine since I'm scared I might end up with holograms or burn the paint/clear coat out.
Which pad and swirl mark remover do you guys suggest? I'm willing to put in some elbow grease to remove these swirls. Do I have to do the entire hood or only the part where these noticeable swirls are present?
My car is moonlight blue (very dark blue). Factory paint.
Please do help me out. Thank you in advance.
Washing your car in the colder winter climates does present a problem for those of us not lucky enough to have a heated garage. A few weeks ago, I applied my waterless no rinse product and it did a good job at removing the most of the mess, but was freezing up on the car within seconds of spraying it on. Snow and slush, mixed with road salts are more of an issue than simple dust and dirt.
No, you don't need (though way preferred) a polisher to remove the swirls/holograms, but you do need to know what you are doing and follow the directions. Car care at this level requires the proper product for the level of paint correction needed as well as high quality pads and microfiber cloths. Don't skimp on them as you will end up with more swirls. Since your car is new, I'd recommend this product from Griot's Garage -https://www.griotsgarage.com/product/boss+perfecting+cream.do.
I have used it on my 2017 A4 with good results. But there are also a ton of excellent products available - as well as informative videos explaining in detail, how to apply and remove them. Here's a question for you - what, if any, protective products (wax, sealant, coating) have you applied to protect your car's clear coat? If none, you will continue to have the same issues every time you get your car washed, especially at a commercial car wash. The chemicals there are harsh and even the better places use the same microfiber cloth to dry your hood, roof and doors as they use to dry the bottom (way dirtier) areas of your car. Wax is better than nothing, a sealent properly applied will give you 6 months or so of protection and a sealant, maybe a year or so. Key to all detailing is preparation.
Detailing to those who do it - is a world of its own, with a gazillion products, you need not be concerned about all the minutia presented there and can find yourself getting lost in the weeds. So my advice would be to go to one of the detailing forums and do some reading up and watch the videos on the detailing basics - washing/drying/polishing/protecting your car. That will help you greatly. But I will also tell you - as someone who fusses about my car's finish, these are not "show cars"or "garage queens" - I realize and accept that (especially on dark colored cars, black being the worst) over time, even with good care, there will always be some type of slight swirl mark or hologram popping up and to think otherwise is unrealistic and will lead to spending too much mental and physical energy agonizing over it, rather than enjoying the fine ride that it is. Final note - and this is just me - if my car were leased, not owned, I'd spend way, way less time worrying about those things. Keep it cleaned and polished - you bet, but spend hours detailing by hand, no way.
#12
Yes. I know exactly what you mean.
I haven't used any wax on my car till now. I was into minor detailing back in India (I paid professional detailers to remove swirl marks and do paint correction though).
And yes. I know that it wouldn't be a good time to detail now considering how I'll be using automatic car washes again since it's too cold for hand washing. And I know it will probably induce more swirls again. So I was wondering whether I should just let it be and do a paint correction and detailing once winter is over. Though since I noticed those swirls, it'll be the first thing I see now.
And yes. My car is leased but I might buy it out once the lease is over. If I don't, my father in law will cuz he loves the car too. So that is why I thought I'd spend some time keeping her nice and shiny.
OT. My BMW has been neglected and always washed at the automatic car wash and yet it doesn't have too many swirls. Wonder whether BMW has better paint or not.
#13
Don't know if Audi's paint (actually, it's the clear coat, which protects the paint) is any softer or harder than any other maker's, but I can tell you on my Brilliant black Macan, you had only to breather on it to get a swirl.
#14
Another option. Find a quality, reputable detailer that specializes in nano coatings (i.e. Cermamic Pro 9H or Opti-Coat Pro Plus). They will do all of the paint correction the apply the coatong. Once done, swirls will be a thing of the past - just wash and dry and your paint will look glossier than new for several years with no waxing necessary. Not inexpensive but I've found it to be well worth the investment.
#15
#16
CQuartz and other DIY coatings are good for about 2 years then usually need to be redone. The pro ones I mentioned can be good for 5 years or longer. Generally, I'm not sure that if one has a leased car, it shouldn't be considered. There's a maintenance/convenience side to that decision if you want the car to look as good as new throughout a 3 or 4 year lease and don't have the time or inclination to periodically wax, polish or do DIY coatings.
#17
Thank you, both of you. I thought I would wait until winter is here very to get paint correction and detailing done since there aren't any around where I live (the closest one is around 30-40 miles away).
I'll get the stuff bob m mentioned and get to work as soon as possible. Problem is the weather. It looks like it is only going to become worse (34F is the highest we've had in the last few weeks). And no heated garage. So yea. Hopefully it won't stop me from applying wax or something.
Btw. Does a sealant like Klasse atleast reduce swirl marks? And also. Will it be easy to remove it by a detailer before I get the car coated?
Thank you so much guys.
#19
I'm not so sure any hand applied product can remove the swirls. If you are unsure of a DIY DA rotary, consider letting a pro detailer do it for you. To avoid swirls in the future, as I wrote previously, consider investing in one of the top nano ceramic coatings. Otherwise, I'll let one of our detailing experts chime in.
