Clutch Pedal on 20v Turbo
What is necessary to change the clutch pedal on a '91 20V? I broke the original one in half, and got the same exact one shipped in, so now it's ready to change.
Find a mechanically dexterous contortionist to help you...
Just kidding. I might suggest getting some replacement clips and pins since I managed to loose one or two when I was working on mine. There is also some kind of Audi tool for the clutch pedal return spring. The spring will pop apart with much force when removed without something to restrain it. One thing to also note, I have seen two different styles of aluminum clutch pedals with the same part number. There may be a letter at the end of the number on one of the parts. The later style for my 200 had a protrusion on the back side that would limit pedal travel. The older style that came from a 5000 had no protrusion. I cut out a chunk of aluminum at my work and glued it on with some 1500lb epoxy.
S6 4RiNGS
Audi Original "S" Cars
05-10-2006 04:19 PM
