removing K24
Old Oct 2, 2008 | 01:39 PM
970-20v-t's Avatar
New Member
Default removing K24
do i need to drain both oil and antifreeze to remove my turbo?
Old Oct 2, 2008 | 07:16 PM
yodasfro's Avatar
Yes.
Old Oct 3, 2008 | 08:05 AM
Melinko bq's Avatar
Default No... but it is recommended.
Oil returns to the block from turbo via gravity only, therefore the turbo must be located above the oil level and oil does not need to be drained.
Turbo is below the water reservoir, however, so you will slowly leak coolant through the head until level. You can plug the lines fairly easily, and it won't make a huge mess. However...
It is recommended that you replace the oil anyway, and likely the coolant system could stand to be replaced, so you should drain both and have replacements w/ oil filter on hand.
Old Oct 28, 2008 | 08:47 PM
Suffolk's Avatar
If you replace turbo, a new Oil supply line probably good idea. Re: removing K24
ranchan02
Q5/SQ5 MKI (8R) Discussion
Mar 14, 2015 08:02 PM
rakta *chchchanges
Mar 26, 2009 03:34 PM
Hutan
Feb 20, 2006 03:22 AM
Havepitty in W.Van
Performance and Tuning
9
Dec 7, 2003 05:26 PM
A4 Firstimer
Aug 8, 2001 04:09 PM
