audi 200 lighting issues
Old Jun 2, 2003 | 09:20 AM
billb's Avatar
Default audi 200 lighting issues
my 91 200 has a weird lighting issue and i believe it to be the switch but i figured i would post it here to see what others thought about it... all of a sudden the dash, and parking lights wouldnt work...it was not the fuse or the bulbs, the headlights worked fine just now i had no dash lights or lights in the rear(started driving with the rear fog as it still worked) then yesterday they started working again... weird... any suggestions????
Old Jun 10, 2003 | 04:10 AM
paulfern2000's Avatar
Default uh oh sounds like some one palyed around with your wiring...
did you have ..or did the previous owner rig up a stereo or alarm system on the car?
Paul
Old Jun 10, 2003 | 07:43 AM
billb's Avatar
Default Re: uh oh sounds like some one palyed around with your wiring...
yes but the previous owner was the manager of an audi dealer and had all the work done by the dealership, the radio works fine, even gets radio reception...never had a problem with it... and now they work again, just started to work all of a sudden.. weird...
Old Jun 11, 2003 | 06:43 AM
audiqv8's Avatar
Default Re: audi 200 lighting issues
Get a wiring diagram and find the common ground or circuit for the dash lights and the lights in the rear.
Old Jan 15, 2004 | 01:03 AM
Will Ng's Avatar
Member
Default Check the trunk wiring harness.
You'll likely find a broken brown ground wire there, among other frayed wires.
I believe the dash ground and the back light grounds are the same, and sourced from under the rear seat.
SpyderTurbo
Feb 17, 2007 08:54 AM
cubstter
Jan 30, 2006 02:02 PM
eelpie
Nov 10, 2005 08:08 PM
jay1607
Oct 27, 2005 07:11 AM
Karl (KvK)
Sep 11, 2003 12:58 PM
