Will 225 45 17 Hoosiers fit on stock S4 wheels?
I've checked on the chart on tirerack site and their suggest rim width are 8-9"... Anyone try that size on stock S4 rims before?
here
<ul><li><a href="http://www.tirerack.com/tires/Spec.jsp?make=Hoosier&model=A3S03%2CR3S03">http://www.tirerack.com/tires/Spec.jsp?make=Hoosier&model=A3S03%2CR3S03</a</li></ul>
yes.
Jerry and I did some testing, and found that 245 hoosiers or 255 kumhos will fit with with a 1/4" spacer. They have to be mounted by someone with experience squeezing super stiff sidewalls onto narrow rims and they will have to use something more tsophisticated than the reguar tire mounting machines you find @ most places.
Oh and they will rub when the wheel is close to lock and rub when the car is close to bottomed out but you can go wider than 225 (which incidentally, I run on my 2,404lb neon ACR racer).
adminisTerTurbo
04-01-2005 06:20 AM
TommyK
Wheels & Tires Discussion
10
12-20-2001 11:23 AM
TTS_4_to_A6
05-19-2001 12:28 AM
Peter L
12-14-1999 07:57 AM
