Performance and Tuning Discussion forum for various performance tuning techniques and questions
1.8t Engine Fault Codes
Old Apr 9, 2001 | 05:41 PM
jsbear's Avatar
New Member
Default 1.8t Engine Fault Codes
16684 Random/Multiple Cylinder Misfire Detected 35-10 ---Intermittend
16685 Cylinder 1 Misfire Detected 35-10 --- Intermittent
Car is out of warranty. Any idea what I may be looking for ? Spark plugs ? Bad gas ?
Any idea would be greatly appreciated.
30k on the car.
THANKS
Old Apr 9, 2001 | 06:21 PM
cpayne's Avatar
Either bad gas..spark plugs or you ran out of gas or near it?
Old Apr 10, 2001 | 07:51 AM
Dr. Mike's Avatar
New Member
Out of warranty at 30K? Which car do you have?
Old Apr 10, 2001 | 07:52 AM
Adam S's Avatar
Junior Member
Also, carbon buildup is possible. Try a high quality fuel system cleaner.
Old Apr 10, 2001 | 08:01 AM
AndrewM (azdaspeed3)'s Avatar
Senior Member
Default not bad gas, same thing happened to me...more
i had a random misfire occur on four separate occasions. i think this is a problem that is basically isolated to 99 and 99.5 cars with NGK plugs. my recommendation would be to go get some better plugs, like Beru Ultra-X or Bosch F7LTCR's. good luck.
Old Apr 10, 2001 | 12:29 PM
JBear::FATS's Avatar
Senior Member
VW Passat 1.8T
Old Apr 10, 2001 | 12:36 PM
Senior Member
Default Is there a SPARK PLUG replacement FAQ. *MORE*
How difficult is it to replace the plugs on the 1.8t motor. Where are they located ? I've done plugs on several other cars. Where is a good source online for the Bosch F7LTCR's ?
THANKS
Old Apr 10, 2001 | 02:09 PM
Dr. Mike's Avatar
New Member
I thought warranty was 36K? You might double check! ;-)
 Michael S. Palmer
Old Apr 10, 2001 | 04:29 PM
Senior Member
It's 1998 Passat, 2 years / 20k
Old Apr 11, 2001 | 12:13 PM
xr4tic's Avatar
Default They are easy to replace....
Pull the engine cover off, then you will see four coil packs, one for each cylinder. Each one is held in with two allen head bolts (5mm or 6mm, can't remember) Pull the coilpack straight out, the spark plug wire will come with it. Then you have access to the plug.
I got my plugs from the dealer, but you can probably get them cheaper elsewhere (clairparts?)
smhoward27
1.8T Discussion
Jan 24, 2011 10:23 AM
ratskinner
A4 (B7 Platform) Discussion
Mar 31, 2009 02:24 PM
snox135
Jun 4, 2006 02:50 PM
Pekboy
Mar 9, 2004 09:02 AM
CrappleZero
15
Jan 8, 2004 08:13 AM
