5.0L V10 cylinder firing angle
I asked this question elsewhere on this forum and got no response, so I thought here would be better place to ask this.
Does any one know if the RS6 5.0L V10 engine is odd fire. I other words the crankshaft rod pins are offset so the cylinder spacing is not an even 72 deg between TDC.
Ray.
Ray.
Ray.
Ray.
Even fire - Good article for you
From Wikipedia (not Audi doc)
The engine (parts code: 07L, identification code: BUH) of the RS6 was what Audi claimed to be the first all-aluminium alloy even firing 5.0-litre (4,991 cc (304.6 cu in)) 90° V10 twin-turbocharged ("biturbo"), Fuel Stratified Injection (FSI), with a dry sump lubrication system. This engine is related to the naturally-aspirated V10 found in the Audi R8, S6 and S8, and the Lamborghini Gallardo, but the RS 6's engine has around 400 unique parts
BUH 5.0 TFSI V10 engine: Audi C6 RS6
The 5.0L V10 BUH engine is odd fire. I has to be as the engine is 90 degV block with two oposing cylinders shareing the same connecting rod pin. The engine roates 720 degess to fire all 10 cylinders. So for even fire 720 / 10 = 72deg spacing. 72 deg cannot work with a 90 deg V as you cannot get all 10 pistions at TDC every 72 deg. The cylinder spacing is 90-54-90-54-90-54-90-54-90-54
This is the position of TDC for each cylinder.
1 = 0
6 = 90
5 = 144
10 = 234
2 = 288
7 = 378
3 = 432
8 = 522
4 = 576
9 = 666
Thank you for your help.
Ray.
1 = 0
6 = 90
5 = 144
10 = 234
2 = 288
7 = 378
3 = 432
8 = 522
4 = 576
9 = 666
Ray.
1 = 0
6 = 90
5 = 144
10 = 234
2 = 288
7 = 378
3 = 432
8 = 522
4 = 576
9 = 666
Ray.
1 = 0
6 = 90
5 = 144
10 = 234
2 = 288
7 = 378
3 = 432
8 = 522
4 = 576
9 = 666
Ray.
Pretty sure it is even fire (crossplane crankshaft with split 18 degree offset crankpins) The offset allows for the 72 degrees needed for even fire.
Any way I just changed the cylinder TDC angles to odd fire and the engine sound much nicer and stronger when reved. I will put it back on my dyno and retune it of the next few days and wil report back here on the difference.
Ray
Ming rings in Minn
01-14-2005 12:15 PM
Boba Fett
NorCal Discussion
04-04-2003 06:08 PM
