Performance and Tuning Discussion forum for various performance tuning techniques and questions
Adjustable rear Sway Links (CPP) {Setting length}
Old Oct 2, 2004 | 07:57 AM
coolhand {aka Craig}'s Avatar
New Member
Default Adjustable rear Sway Links (CPP) {Setting length}
Anyone have comments on the appropriate length of these when the car is lowered from factory height?? bear with me:
Most folks seem to set the adjustable rear sway links to the same length as stock ones before they put them on. typucally they are going on cars with either a Sport bar, Neu bar or Hotchkis H Sport bar anyway. Typically they are being installed due to rubbing (or to prevent rubbing) on the shafts (q cars). IE - the car is lowered. I would doubt most people actually fine tune these, as its their primary design purpose, but some certainly do.
2nd part of the equation:
So, the car is already lowered, and the bar is likely adjustable for stiffness.....so why would the uplink be set to the stock length?? I dont know the answer, im facilitating some responses from others who may have some data. I cant determine if it will effect setting the alignment or prevent an optimal alignment from beign completed ? (all other CPP stuff is installed as well).
Wisdom is appreciated.
Old Oct 6, 2004 | 12:21 PM
A400's Avatar
Default Eric you are a track guy, what would you go with on the CPP stuff
Stassis only sells part and I am not that crazy about their stuff in general so what did you do to yours for tracvk/drive. Hi power car with a LSD already and a rs2 6sp.
Rod
Old Oct 11, 2004 | 05:18 PM
A400's Avatar
You have been into suspension on these for awhile what cpp parts do you recommend?
MikekiM@PureMS
Jul 14, 2009 11:53 AM
KCRS4
RS4 (B7 Platform) Discussion
Apr 28, 2009 08:40 PM
iconoclast
18
Feb 18, 2007 09:05 PM
MarkW
15
Jun 30, 2006 03:30 AM
jaxjax
14
Mar 9, 2004 06:36 AM
