Performance and Tuning Discussion forum for various performance tuning techniques and questions
APR stage 1 and injectors vs AWE K04 with GIAC Software??
Old 04-24-2005, 11:24 PM
Member
Quattro4lifeAus's Avatar
Default APR stage 1 and injectors vs AWE K04 with GIAC Software??
<center><img src="http://www.awe-tuning.com/media/products/awe/k04kit_sm.jpg"></center><p>Just ding some online browsing and have come accross the figure for two different paths of tunning and am amazed at the similar result.
Below is an extract from the AWE site
AWE K04 Turbo Upgrade Kit
Extraordinary Power
235 hp !!!
265 ft/lbs Massive Torque !!!
Free flow exhaust *required* for use with this kit
Below is an extract from the APR Site
Stage I+ ECU Upgrade
Stage I+ software, along with larger fuel injectors*, provides even more horsepower and torque, raising the output to 235 hp (175Kw) and 275 ft lbs (372Nm), respectively. While not an extreme upgrade, the Stage I+ gives the A4 a bit more performance without sacrificing drivability or smoothness. For optimal results, our cat-back exhaust system is highly recommended with the use of the Stage I+ system.
I would have concluded that the AWE kit with a larger turbo and related software would have left the APR injectors and related software for dead...IS AWE understating its performance figures?
Old 04-25-2005, 06:05 AM
Pat
Pat's Avatar
I would guess the AWE kit is more reliable due to the larger turbo.
Old 04-25-2005, 06:14 AM
bhvrdr's Avatar
Default edited: the AWE software for the K04 is brand new and likely not dialed in yet...
But your post confused me.
The AWE K04 for the B6 is brand new but not for the B5 which is the 2000 MY car.
For a B5 you could go AMS, MTM, GIAC, Neuspeed and probably a bunch of others for a K04.
The chip numbers come out a bit better on the B6 car than the B5 due to a slightly better K03 turbo used on those applications.
cheers! Mike
Old 04-25-2005, 06:23 AM
Elder Member
Audi2ptzero's Avatar
Default Looks like your comparing 2 setups for 2 different cars.
The K04 kit is for the B5 while the APR chip/injector setup is for a B6.
Now if you have a 2000 with a P box ecu, then you want to use the J31 chip which puts out 250 hp and 320 tq.
Old 04-25-2005, 12:03 PM
New Member
A4 4Play's Avatar
AWE... The APR kit is tuned for the new fuel system on the B6
Old 04-26-2005, 01:22 PM
Member
Default I see...so even though the engine is the same...
the fueling system behind it has more potential for power upgrades or is it due to new fly by wire tech in the B6.
Is it time to leave the B5 behind in the quest for power numbers and move to the B6 or even the new B7? (i never want to sell my B5!)
Old 04-26-2005, 01:54 PM
Elder Member
Default Well it has more to do with the K03.
As for big power, your better off staying with the B5 since there are very little turbo kits out there for the B6.
If your looking at going to a K04 your 2000 might be the perfect car, just depends on what ecu you have.
Old 05-02-2005, 03:57 PM
RedBlackYellow's Avatar
how much do the larger injectors eat up your gas mileage?
Aaron12V
27
11-07-2005 11:58 AM
addifan
02-22-2002 10:04 AM
matador
11-27-2001 06:26 PM
Kid
07-25-2001 01:31 PM
KenHuglr
11-01-2000 03:39 PM
Quick Reply: APR stage 1 and injectors vs AWE K04 with GIAC Software??
