Bad things happening. NEED HELP.
Perhaps you can help me with a problem that just started. As of about three weeks ago my A4 started having problems starting. The symptom is very strange. The car will run just fine until I turn it off. If the car sits for more than about 20 minutes, it just refuses to start. I noticed that the EPC light just doesn't come on. If I switch the car on and off enough the EPC light will eventually come on and then the car starts. Once in awhile the car will start run for a couple of minutes then just die. Again, the EPC light just will not come on until I switch the car on and off about a dozen times. It's very strange, once the car in running it stays running.
Here is what I've done to this car.
APR Stage II ( Chip & Exhaust )
Conical air filter
That's it.
If you have heard of this or just have an insight into what it might be I would greatly appreciate your input. I am taking the car in to my Audi dealer. I'm just nervous about them not covering whatever this problem is.
Thanks,
Todd
It is not a major problem the dealer just need to change a sensor (or sensor for the immobilizer).
I cost me $25 in my country. - I had the same problem for my previous A4 1997.
