Battery relocation question.
I have run them, but the local region sucks.
If the fuse is properly sized (which was the whole point of my original post), it will only blow if there is a short...if there is a short, the airbag wouldn't deploy anyway.
If someone were going to use the "airbag not deploying" argument, I would suggest that the battery should not be relocated in the first place. Relocating the battery does introduce additional points of failure (12' of additional wire & a battery in an arguably more vulnerable position in case of accident).
I would argue that the "airbag argument" would be a better argument against relocating the battery than it would be against using a fuse on a relocated battery.
*sigh* 'getting there
Your airbag scenario is highly unlikely. What would cause this instantaneous short? The accident? Well if that's the case, from what I understand about the operation of airbags, they deploy so quickly that they would deploy before any short or blown fuse would occur. Furthermore, given that the battery is located in the rear of the car, the likelihood of being in an accident that would cause the fuse to blow and the airbags to deploy is relatively slim.
Besides, the particular car that I am relocating the battery in doesn't even have an airbag to begin with.
If you are going to keep coming up with your unsupported by reality hypothetical situations and continue to "talk down" to me, I'd rather end this thread right now.
If however, you can come up with a valid argument based on a real-world scenario and factual information, please continue.
question: do you see that on a rally car things arent so weather-proof so squidix there has corrosion problems that you'll unlikely encounter?
question: are you still moving your battery?
question: any particular reason youre moving it?
opinion: articles are opinions.
opinion: heavy duty cables require real good shears
opinion: in a major accident, its possible your plastic box will just shatter toppling your battery with both its terminal shorting
peace.
