bigger injectors
bigger injectors
I am after tuning my car up and im am thinking of buying a set of bigger injectors as my local tuner says this is a good place to start im happy to do this as long as it gives me enough horses so can any one help me andf he says it makes me motorsound good to also how much is an air filter for it thanks alot my car is a 2.6 A4 V6 im from the uk
I disagree. The stock injectors are good only to 225 HP...
AND if you dial up the duty cycle to 90+. This reduces the reliablity and longevity wonce you ramp above 95%. The car might need to run lean too to extract that much HP from the puny270cc injectors that the car comes with, leavig the chance for pinging and detonation.
Larger injectors are definitely the way to go, but REQUIRES special tuning and ECU programming to deal with the greater flow potential. the duty cycle is lower for a given RPM than stock, and if this is not done right, you run VERY rich. Might not even run at all.
ok, 225hp, do you see a audi doing this without a new turbo or other big mods?
no, so youre WRONG! ed. just kiddin
+ its a 2.6, 225p from less disp.. than a 2.8, it will take a bit to get there
UrS4boy
Audi Original "S" Cars
11-03-2007 01:19 PM
DAP@EPL
51
03-20-2006 08:33 PM
a4kquattro
12
01-15-2005 07:28 PM
MichaelTM
11
01-22-2003 06:39 AM
