Does anyone know how to...
Here it is:
<img src="http://pictureposter.audiworld.com/12130/transfer2.jpg">
If you only need a few points, you can use the pic, otherwise, I've got the 256 data points the ECU uses.
1st is by hacking the ECU and interpretting what the transfer function is.
2nd is by having the stock meter flowed
3rd would be to put a meter with a known transfer function inline with the stock meter, and datalog both.
So after talking to soem people he decided he wanted to give it a shot. The VPC is not only a dinosaur but its not even in production anymore, the AFC has lmitations on how big you can go, and the GM maf was really the first option till this came about.
Anyway, it has an auto learn function in which you run it with your maf in place, this way it learns how psi/rpm related to hertz and so forth.
Problem is, we have to run it on the stock turbo, because if we run it on the 20g we will hit fuel cut INSTANTLY.
So it autolearns on the 14b, or and then we will have to adjust it accordingly, which Im not sure how to do, OR we write the map from scratch.
Input values on it are in hertz...so I believe.
But take a look, show a friend and let me know what you think we can do about it
<a href="http://www.performancemotorresearch.co.nz/index.html">Heres the link</a>
I'll e-mail this thread to my DSM guru and get back to you.
