Performance and Tuning Discussion forum for various performance tuning techniques and questions
Does anyone know how to...
Old Dec 4, 2003 | 05:53 AM
  #21
xr4tic's Avatar
Default You'd have to hook it up to your MAP-ECU thingy....
And based off of it's readings, calculate MAF, and compare it to what the MAP-ECU says the input Hz is.
Old Dec 4, 2003 | 11:46 AM
  #22
YellowA4Turbo Ownz's Avatar
Junior Member
Default do you think
that the hertz will remain linear?
Like lets say this.
Lets say I figure out that the maf is reading 22 lbs/min at 3000 rpms, stock and at that its 2100 hz.
Then at 3100 rpms its at 23 lb/min, 2200hz. This is just an example.
So can we say that for every 1000 rpm, there is a 100hz incriment.
You think it would remain linear?
Old Dec 4, 2003 | 11:47 AM
  #23
Junior Member
Default do yo u know where I can get
boost speed temp calc?
Old Dec 4, 2003 | 12:42 PM
  #24
xr4tic's Avatar
Default Don't know....
Voltage MAF meters aren't linear. They do get somewhat linear at high-flow values though.
Try and get like 10 data points, and graph a curve. You can then figure out how to alter that curve.
Old Dec 4, 2003 | 06:58 PM
  #25
Kevin K2's Avatar
New Member
Default Re: do yo u know where I can get
i'm sure that piggy back ecu vendor would provide an initial map, using inhouse spreadsheets for those calc's. lots of info on speed density systems on the net.
Old Dec 5, 2003 | 11:19 AM
  #26
Junior Member
I think we have it figured out
Old Dec 5, 2003 | 11:20 AM
  #27
Junior Member
Default it came with a map
and it has an autolearn feature.
We can only autolearn it on the 14b though
I we try to autilearn it on the 20g, we will hit fuel cut.
Old Dec 7, 2003 | 02:02 PM
  #28
Kevin K2's Avatar
New Member
Default Re: it came with a map
ask 'em for a conservative map for the big turbo, based on max expected boost and rpm, and big inj size. auto learn not an option here. lots of dyno time with wide band. also need to verify eng will start properly with big inj's.
 Michael S. Palmer
n2000snake
Oct 25, 2007 01:02 PM
QuattroJay
May 5, 2006 12:05 PM
germantoy
Audi Original "S" Cars
Aug 23, 2005 07:59 AM
DAP@EPL
10
May 25, 2004 06:30 AM
