Performance and Tuning Discussion forum for various performance tuning techniques and questions
Does anyone know how to...
Old Dec 3, 2003 | 12:17 PM
  #11
xr4tic's Avatar
Default What you can do is.....
hook it up with 20G in auto-learn mode, and just do normal driving, and limit the boost to ~10psi or so.
From there, you should be able to extrapolate an extra-rich fuel curve, and then tune it to an appropriate A/F ratio.
However, if the stock MAF is too small, than what good is trying to emulate the stock MAF? If it hits fuel cut when the stock MAF maxes out, then it will do the same thing when the MAP-ECU maxes out.
So basically, you'd have to auto-learn the stock MAF and injectors, then put in the larger injectors, and adjust the MAP-ECU table accordingly.
Or do you have a way to adjust the ECU values as well?
One thing I notice about this unit, is that it is not a true speed-density conversion. It does not take into account air temp, at least not that I can see.
100F vs. 130F has ~5% air mass difference, this could cause problems going from summer/winter
Old Dec 3, 2003 | 12:58 PM
  #12
A400's Avatar
#2 suggestion is only one without potential problems
Old Dec 3, 2003 | 01:16 PM
  #13
Kevin K2's Avatar
New Member
Default $.02
for a large hp increase, looks like a pia unless a near fully populated map is available. speed density tables depend on VE, which can really drop well below na values at high boost/rpm. lots of tunning time.
no temp correction means over-rich or multiple maps needed. no closed loop could be trouble if inspection is req'd.
the gm 3.5" MAF translator looks better, but not sure how well it can be trimmed for much larger inj's, keeping load based timing correct.
Old Dec 3, 2003 | 02:09 PM
  #14
YellowA4Turbo Ownz's Avatar
Junior Member
yes
Old Dec 3, 2003 | 02:11 PM
  #15
Junior Member
Default ok so...
lets say I build the map from scratch. Autolearn with the stock maf with the smaller injectors and the 14b is useless.
So, now I come to this problem. The diagram that I have to enter vaules into is in Hertz. So lets say I break out all the formuas and such and make a determination what the air mass will be and such and such and prm and what the psi will be and then I can plot a map...BUT I dont know what the damn Hertz are
PS-it does have intake temp
Old Dec 3, 2003 | 03:19 PM
  #16
GSX-Man's Avatar
New Member
Default here's the problem...
This has already been mentioned, but no matter what you do with the new setup, you won't get rid of fuel cut unless you get an ECU mod. If you need some contact information for that, let me know.
Personally, if I had a 1g, I'd go with a MAFT and a SAFC to finetune the MAFT after I got the ECU mod for fuel cut. It's a very proven combination (550+ HP and well into the 10s), and driveability with the MAFT is like night and day compared to a VPC combination.
It'll give you the adjustability you need to tune whatever you throw at the motor for airflow. There are a bunch of guys in New England that are very well versed in this combo, and if you need some specific info, hit me with an email and I'll put you in contact with them if you want some datalogs or other info.
Old Dec 3, 2003 | 03:26 PM
  #17
xr4tic's Avatar
Default the datalogging might be able to tell you that....
Using temp, RPM, pressure, displacement, and VE, you can tell what the actual mass-flow is.
You'd have to guess on the VE, but the rest you should be able to use and calculate a close guess.
Old Dec 3, 2003 | 07:11 PM
  #18
Junior Member
Default I know how to get mass air flow from
temp, ve, displacement, and pressure, rpm.
Heres what I run into. Lets say I determine that:
2.0 liter engine (122 CI), 3000rpms, 90% natural capacity/2.15Densiy Ratio, 34.97 g/CF air density. We get a MASS of 9169.1 g/min.
Heres the problem I get:
How many hertz is 9169.0 g/min?
 Michael S. Palmer
Old Dec 3, 2003 | 08:22 PM
  #19
Toaster29's Avatar
Default It is..
The unit on the DSMs and Evos uses the frequency shift of an FM signal sent through the vortexing air to determine how much is flowing through it. Totally different than hot wire.
Old Dec 3, 2003 | 10:23 PM
  #20
Kevin K2's Avatar
New Member
Default Re: I know how to get mass air flow from
u can get maf sensors flow calibrated vs volts, I recall vk sensors can also be calibrated for hz vs flow. you then offset that curve for say 50% bigger inj's, scaling all flow values by 1.5x for ea hz value. That is your final chart for mass flow vs hz, with 660 inj's. then fill the map up with boost-speed-temp calc based mass flow points, then switch those to the coresponding hz values.
then richen everything about 5% for a safe start for your extensive wide band testing to follow.
this should delay fuel cut (high flows give lower hz vs stock curve), but may mess up timing curves based on load interpretation.
