ECU flashed tune and TD1 mark on dealer (void waranty)
Hello everybody.
Just considering to have ECU Malone tune through FlashZilla.
Still have some warranty and wouldn't like to loose it. Definitely will be flash to stock before visiting dealer for any case.
Is anybody who did ECU upgrade, get flagged as using tune (TD1 mark on file) while being back to dealership with stock flashed back after tune?
Is that possible to have two ECU - buy ECU for same year and model, flashed with tune and used it and put back original ECU when visiting dealer?
Will it work?
Thank you.
Will it work?
Thank you.
Hello everybody.
Will it work?
Thank you.
Will it work?
Thank you.
AFAIK the only tunes not detectable are piggyback tunes when remove from the system before going to the dealer but I could be wrong. You want to play it safe, don't mess with a good thing and leave it as is. .02
Hello everybody.
Will it work?
Thank you.
Will it work?
Thank you.
Is the ECU modified or touched AT ALL with the Flashloaders? Or does it all electronic to stock ECU?
Alex (lil' is 300)
02-04-2006 04:23 PM
djnelsen
05-20-2004 03:04 PM
S4 SOM
08-06-2002 08:13 AM
