Front and Rear Fog Lights automatically ON!
After the relay modification on my 01' A4, sometimes when starting the engine the F & R fog lights come on automatically. As if the bottons were pressed to the ON position. Is anyone experiencing this on their A4. I can't see the logic. :-) Thanks!
Mine did that every morning (or anytime it sat for 8+ hours)......
so I pulled the relay back out, un-soldered the wire (I did the inside wire job), and re-soldered a longer wire on, then wrapped the wire in electrical tape. Closed the relay and pluged it back in. That was last weekend, and it has not happened since. Did you solder the wire on the inside or outside? I did the inside job because it did not look like there was enough room on the outside to still plug the relay in all the way. Hope this helps. E-mail me if you have any questions.
JessicaK
01-21-2011 04:20 AM
jurq
11
03-13-2007 05:48 AM
Åudios69
11
12-15-2002 06:53 PM
