Help! Problems and DTCs
You cant check the MAF without a special adapter harness from VW. You can use your Scan tool to check range..
Hope this helps..
Clark
I don't understand it, if I let up just a little, it goes away. It's almost as if the fuel pressure drops, then kicks back in. Maybe the fuel pump gets shut off? Is there a way to tell?
