Performance and Tuning Discussion forum for various performance tuning techniques and questions
Idle problems
Old Jan 18, 2005 | 11:16 AM
  #21
goody6691(gt3076 )'s Avatar
New Member
just get the 3in maf from atp then put 550 injectors in it will run fine
Old Jan 18, 2005 | 11:18 AM
  #22
New Member
that was me
Old Jan 18, 2005 | 12:04 PM
  #23
TomRitt (Homebrewed)'s Avatar
Ok will do when I get a chance. Probably tomorrow.
Old Jan 18, 2005 | 12:06 PM
  #24
Default The only thing is I got the 475cc injectors file from them but I'm going
to email them and see if they will change to the 550 file, then I will get some 550 injectors. I am going to try a new maf before I do anything else though.
Old Jan 18, 2005 | 12:09 PM
  #25
Thanks, any word on the maf? I'll buy it off you!
Old Jan 18, 2005 | 12:20 PM
  #26
SMOKINA4TURBO's Avatar
Member
Re: I'll go look today...
Old Jan 19, 2005 | 11:43 AM
  #27
xr4tic's Avatar
Default my 580cc injectors have no problems idling....
and neither did the "green top" 440s I had before that.
My guess is that it's software or MAF-related
Old Jan 19, 2005 | 11:49 AM
  #28
xr4tic's Avatar
Default Define "S4 MAF Housing"?
is it a 3" housing that you put your stock MAF element into, or did you just put in the whole S4 MAF, element and all, and plug it in?
If you did the latter, then the S4 MAF element will have a different transfer function than your stock element, and will totally mess up your chip.
MAF sensor voltage when idling should be low, right around 1V or so, make sure you didn't put it in backwards.
 Michael S. Palmer
Old Jan 19, 2005 | 01:45 PM
  #29
Devious27t's Avatar
Member
i have your greentops. and the car idled like **** with em
Old Jan 19, 2005 | 02:59 PM
  #30
Default Oh good point, S4 maf housing with my element inside it.
I'm still looking for a vr6 maf as thats what my ecu is programmed for, but wouldn't that make my maf reading even higher?
BTW thanks for the great article on installing the fuel pump, I'll be using it this weekend to install my Walbro. Anything else I should look out for? Thanks!
