Performance and Tuning Discussion forum for various performance tuning techniques and questions
Possible Throttle problem??
Old Aug 27, 2002 | 06:03 PM
?lueshirt's Avatar
Senior Member
Default Possible Throttle problem??
Experiencing engine stutter in all gears, (2nd and 3rd the worst) all around the same rpm (3k-4k). Under WOT no stutter, but at 1/4 throttle position is where I experience it the most.
No error codes or CEL's.
Ideas?
MAF replaced, running GIAC xchip. I have a new N75 that I will be putting in shortly but I don't think that is the problem since it does not seem to be a boost issue.
Old Aug 27, 2002 | 07:30 PM
johnAWD's Avatar
New Member
Default Re: Possible Throttle problem??
Perhaps a leaking blow off valve (diverter valve?)?
Old Aug 27, 2002 | 10:02 PM
Dave_4's Avatar
Junior Member
Default I had similar symptoms... did the Throttle Adaptation... and *poof* problem disappeared.
Now slow acceleration is smooth.
Dave.
Old Aug 29, 2002 | 06:12 PM
?lueshirt's Avatar
Senior Member
Default I tried.
Was told to leave the key in the ignition for 3min and it will adapt. Nothing happened.
Old Aug 30, 2002 | 05:41 PM
Dave_4's Avatar
Junior Member
Default This MAY be the correct procedure... but not sure. I use the VAG-COM (see inside)
Oops, forgot: I also redid my throttle adaptation...
User account number (aid): 3044
Posted by mule_x on 2000-10-21 19:34:45
In Reply to: I had the same symptoms... posted by mule_x on 2000-10-21 18:23:14
After I returned to NorCal, I redid my throttle adaptation by disconnecting the negative ground on my battery for 15 minutes. After reconnecting, I put the key in the ON position for 5 minutes.
I'm not sure when I redid the throttle adaptation, but it was probably the day after the 104+, and before switching to Shell gas.
Let me know if that works...
Dave.
AudiSportB5S4
Sep 18, 2008 11:40 AM
audi80greece
Audi Original "S" Cars
Aug 19, 2005 05:12 AM
Matt E.
Dec 8, 2003 08:08 AM
DrewP
Nov 4, 2003 06:15 PM
