Performance and Tuning Discussion forum for various performance tuning techniques and questions
power ... where are you?? (help needed)
Old Sep 1, 2006 | 06:37 AM
sans's Avatar
New Member
Default power ... where are you?? (help needed)
Last month I had a GIAC chip installed in my 98.5 A4 1.8TQM. You couldn't wipe the stupid grin off my face as I was being thrown to the back of my seat.
Last week, however, I lost the "umpf", and now the car feel more-or-less stock. I can't even be sure that the turbo is spooling anymore.
I put the key in the "on" position (without starting the car) to re-synchronize things, but no luck. I even unplugged the battery in hopes of resetting the ECU, but still no change.
What could be wrong? Is it the ECU? The turbo? The DV valve? (I had a Forge installed 3 years ago in anticipation of future power upgrades)
History - half a year ago I installed a Milltek cat back. It seemed a little louder than expected based on comments in the post, but the installer couldn't find a cause for it (it's "normal"). Now around the same time as my power-outage it seemed that the exhaust got even louder. Can they be related? Possibly a leak at one of the joints throwing the O2 sensor readings out of wack?
Help!
1998 A4 1.8TQM
GIAC Stage 1
Milltek Exhaust
Forge DV Valve
Brembo Rotors
EBC Pads
Spec Stage 2 Clutch
Spec Steel Single Mass Flywheel
Old Sep 1, 2006 | 11:10 AM
JAFO's Avatar
first thing i'd do is reseat the chip, then check the dv.
Old Sep 1, 2006 | 11:23 AM
Ray Khan's Avatar
I wouldn't bother, if the chip wasn't seated, the car wouldn't run right?
Old Sep 2, 2006 | 03:38 PM
Atomic864's Avatar
New Member
Default The same thing happened to me 3 years ago. I was disappointed with the power output
and installed an APR chip. It did okay for a bit, but then felt weak (and I wasn't hearing the turbo either). I think that my turbo was going out and the more aggressive programming finished it off. I bought a used KO3, but then ended up upgrading to a Stage 3. I would check the turbo. BTW, mine didn't throw a code
Old Sep 15, 2006 | 02:55 PM
dgkula's Avatar
Default You may be getting used to the chip or turbo may be on its way out
Are you seeing any DTCs?
Old Sep 29, 2006 | 01:29 PM
sans's Avatar
New Member
DTCs???
Old Oct 3, 2006 | 06:27 AM
dgkula's Avatar
Diagnostic Trouble Codes (seen with an OBDII scanner or VAG COM)
Old Nov 14, 2006 | 08:29 AM
sans's Avatar
New Member
It was the vacuum hose to the DV ... all's well now!
 Pouria Savadkouei
 Michael S. Palmer
HyperS4
A4 (B9 Platform) Discussion
619
Nov 18, 2021 06:36 AM
PKBlu::E30 Hunt
Jan 13, 2003 01:02 AM
Tekno
12
May 31, 2002 11:05 AM
TozT
11
Jan 5, 2001 09:34 AM
