Performance and Tuning Discussion forum for various performance tuning techniques and questions
reprogram ECU codes (Please help verify)
Old Sep 15, 2005 | 12:39 PM
mxp's Avatar
mxp
Audiworld Senior Member
Default reprogram ECU codes (Please help verify)
Need help in confirming my coding:16751. There seems to be conflicting info on AW posts. My car is a 2001 (not .5) A4 1.8TQ Auto/Tiptronic ESP.
Current Data:
Chassis Type: 8D - B5 Audi A4
Address 01
Controller: 4B0 906 018 CH
Component: 1.8L R4/5VT G 0001
Coding: 16751
Shop #: WSC 06435
16 = USA - Country Emissions? Some AW posts indicate 06 instead
7 = ?? What is this ??
5 = Auto/Tip
1 = A4
I have a separate APR chip/CH box that I need to recode and install in my car. I need to confirm that 16751 is the code I need to recode this APRchip/ECU CH box.
Thanks.
Old Sep 15, 2005 | 08:30 PM
Yippers®'s Avatar
Member
Default The 06 is the country code for a different engine/model year.
AWM is 16 for USA/NorthAmerica country code/exhaust. The next digit (third place holder)is 0 for Front wheel drive with ABS, 2 for All wheel drive with ABS, 5 for Front Wheel Drive (FWD) with ASR/ESP or 7 for All Wheel Drive (AWD) with Electronic Stability Program (ESP). The fourth place holder is for transmission 0 for the 5 speed or 5 for the auto. The last place holder is for the model, 1 for A4.
Old Sep 16, 2005 | 07:34 AM
mxp's Avatar
mxp
Default Thank You Yippers! Is this the only thing I need to do to...(m)
... to get the APR chip/CH box ECU ready for my car?
I don't need to change any other values in other channels?
Thanks.
Old Sep 16, 2005 | 11:16 AM
Yippers®'s Avatar
Member
Default If you are a CH box nope that is it. If, however, you are a M box I'd call
APR to verify the M to CH switch compatability. I've read here that GIAC M to CH seems interchangable but I'd confirm APR's position.
Old Sep 19, 2005 | 06:25 AM
ModifiedA4's Avatar
Banned
Default what yippers said
this is for upto 2000 (my 2000 had "07" as the first two digits):
<img src="http://www.modifieda4.com/images/technical-docs/A4_ECUcoding.gif">
LJH
14
Mar 14, 2022 12:19 AM
rakta *chchchanges
Apr 19, 2009 11:30 AM
StrikerNo9
VAG-COM Discussion
Apr 24, 2005 04:46 PM
Uber Wagon 2.0
Oct 11, 2004 06:58 AM
Ben3.2TT@BC
May 24, 2001 10:24 PM
