Performance and Tuning Discussion forum for various performance tuning techniques and questions
tech performance questions(longish)
Old Jan 22, 2001 | 08:15 AM
  #11
LCP's Avatar
LCP
AudiWorld Expert
Default ...and even if you meant high 12's...
APR is working on a ~400hp Stage IV kit -- that should see the high 12's.
Old Jan 23, 2001 | 02:49 PM
  #12
Dave Schotz's Avatar
New Member
Default Re: Not even the S4 ... Not exactly true... I ran 13.0 @ 105.9 with busted mount, ...
I had posted the info quite a time back, but I took our APR equipped Chipped, and Exhaust S4 to the track, and in 75' AZ 1350 ft elevation, I ran 13.0 @ 105.9... We plan to go back to the track and get the 12 soon, it has cooled off a bit now!
Peace,
Dave Schotz
http://www.sccaforums.com<ul><li><a href="http://www.sccaforums.com">http://www.sccaforums.com</a</li></ul>
Old Jan 24, 2001 | 10:42 PM
  #13
Jose A4's Avatar
New Member
Default Sure but you'll have to go into uncharted terrritory...
1.) No, because it is allready installed. The ECU controls the boost. This is a much better method compared to the crude HKS and Greddy type boost controllers that do not take into acccount the rest of the engine (fuel delivery, rpm, etc...)
2.) Yes and no! Assuming you have enough power (Hp) and you have upgraded the stock clutch, then yes. You can put a lot more Hp to the ground. But remember, a lighter car is always easier to accelerate!
3.)Yes, try APR at (goapr.com) they're using a Garret turbo.
4.)Well, I have heard of 550+ Hp but I am not sure how much the internals were changed. (Dahlback Racing or something like that)
Finally, I believe YES you could get into the mid 12's. How? That is the question! I would work with a tunner such as APR for example. Get their 330 Hp kit and have a 6mm head gasket installed to lower the compression ratio (or different pistons) so that you can have custom ECU programming that allowed you to run 25psi of boost on 93 octane and something crazy like 35psi or so with race gas. I am sure by now you'll be running the RS2 tranny, a racing clutch, a carbon fiber hood with a RAM air scoop for your custom built intake system.
Basically when you're done you might want to sell the car for a more practical one, and the cycle begins again... Goood luck!
Jambo1874USA
9
Sep 12, 2008 11:48 PM
carguy987
20
Jan 10, 2007 01:05 PM
quatro guy
1.8T Discussion
Oct 4, 2006 10:07 AM
BoostedA4
Feb 24, 2002 12:35 PM
Andy
Sep 2, 1999 06:31 AM
