VAG-COM tool, where I can get one? How does it look like? I've seen those boost graphics some of you
post here, and perhaps it can help me to find what is wrong with my engine. Cause it feels like a normally aspirated car now, lot of turbo whistle and not pulling the car like before.
By the way Electro Man, thanks for the knock sensor info, but I'm not sure if VW shop is right, telling that Knock sensor is the cause of my week engine, is the low-end power (torque) what I miss more. Do you think it is the real cause?
I have the suspect of the wastegate or turbo failure, or even a defective ECU, don't trust these VW guys (I live in Mexico).
So I'm wondering if this tool can help me to find out what is really happening.
any comment??? advice?
some info
go to <a href="http://www.ross-tech.com">Ross-Tech</a> to buy a VAG. You most likely will find a DTC (diagnostic trouble code) through VAG-Com. With the info VAG-Com gives you, you will have a much better idea of what to look at and where to start. As far as boost pressure charts, VAG-Com itself does not do graphing. You can either log the numbers in VAG-Com and import them into Excel for a graph, or use VW Tool, which does graphing. I don't think you can buy VW Tool anymore, but I'm sure someone here (email me) will be kind enough to give it to you
hope this helped... josh
davids_s4
16
10-24-2006 03:02 AM
bjaro5187
01-06-2005 03:41 PM
malcho
10
07-23-2003 03:10 PM
