What sensor inputs does the ECU use in Open Loop Mode?
I'm trying to test all sensors that give input to the ECU to determine if I have a faulty piece of hardware or my software just isn't tuned correctly and I'd rather not have to test more sensors than I really have to.
Thanks,
-Brent
2000 1.8TQMSX +K04 and other stuff
Once the ECU sees WOT, it looks at Manifold Absolute Pressure (MAP) and Mass Air Flow (MAF) sensor values to determine air mass. Once air mass is determined, ECU uses preprogrammed values to determine fuel delivery (injector pulse width).
There are also sensors (knock-two and intake air) that the ECU monitors when deciding how much timing advance to use. Ignition timing control is independent of throttle position.
Thanks!!
-Brent
Audiboy is right about the MAP sensor. There is no MAP sensor. There's a boost sensor that pretty much serves as a feedback for closed loop boost control in dbw cars. On nondbw cars boost control is load based so it's entirely dependant on load calculated from MAF readings.
