Performance and Tuning Discussion forum for various performance tuning techniques and questions
wheel alignment settings for lowered A4
Old Dec 23, 2000 | 03:13 PM
97A4 1.8T's Avatar
New Member
Default wheel alignment settings for lowered A4
i have the H&R sport springs (35 mm lowering) in my car. i'm just wondering what is the best settings to use with these springs in terms of camber, castor, toe... etc..
the car needs an alignment coz one of the rear wheels looks to be out. should i go back to the factory settings or are there better settings for this setup?
Old Dec 23, 2000 | 04:54 PM
Rich L.'s Avatar
Member
Default I used the factory settings where possible.
Some of the more serious track guys were talking about this in the racing forum last week. But with H&R Sports I just used the factory specs where possible. The front camber isn't adjustable so that's out. But toe and caster is to spec. I get nice neutral handling and no odd tire wear yet.
1.4 camber 1.2
4.6 caster 4.4
.17 toe .18
1.3 camber 1.2
.18 toe .17
Good luck,
Rich
Old Dec 23, 2000 | 05:33 PM
®ob's Avatar
I posted this info just about a week ago on this forum...
Old Dec 23, 2000 | 07:02 PM
Clark@turbo5.com's Avatar
Junior Member
Default Info..
I would use the factory heavy duty sport settings for your car.
I race my car so I changed the toe a bit. I like a bit less toe up front.
Remember: The front Tie rod ends are adjustable for hieght. They need to be lowered at the outside edge. Most shops/people dont know this. Look at the tie rod end near the top of the front tire for the adjustment. With you setup you would want to go all the way on it. There is not much adjustment there to start and every bit helps.
Clark<ul><li><a href="http://www.turbo5.com">http://www.turbo5.com</a</li></ul>
Wjballz
Mar 6, 2005 02:15 PM
Bahookie
Jun 7, 2002 05:32 PM
shorki_07
Apr 6, 2001 12:11 PM
pixA4
Feb 26, 2001 05:24 AM
TT NIUM
Wheels & Tires Discussion
Jun 12, 2000 05:05 PM
