Where did the coolant go?
I have a 2001 s4 that is losing coolant. I have checked for leaks. I tested for hydrocarbons and pressurized the system.. Nothing. I lost about half gallon in a week..
So my question is this. Are the turbo's running coolant and oil like the saab's do. If this is the case do you think i have lost a seal in the turbo.. I have a few spare sets of turbos down at the shop so replacement is possible.. Any ideas.. The car is running strong still!!!
I would look under the expansion tank for the tell tale signs of dried coolant...
I was losing coolant, turns out I had a couple hairline fractures on the bottom of the expansion tank that would only actually leak when the car was hot and running... so I never had a puddle under the car, but if I poked around in the engine bay, I would see the dried flakey mess of dried up coolant.
At the worst times, I could smell the coolant even... I would say you should drive around, beat the car up a bit and get it nice and hot, THEN look around under the hood... before it cools down, do it while it is running as well.
Re: Where did the coolant go?
i will check the tank. there are a few small cracks on the top but no sign of any leakage.. i will run the car a bit today and check it later... thanks
s4purchaser
12-01-2007 08:22 PM
davids_s4
02-20-2007 05:24 AM
tkarwin
02-07-2007 08:54 PM
sean7
08-24-2001 01:39 PM
