Brake caliper cleaning
Winter is almost over here and I would like to restore the finish of my brake calipers. Any tip? I don't want to paint them.
AudiWorld Expert
There are brake cleaning sprays but if the caliper is corroded some then painting is your only solution. You may need to wash the brakes more often in winter if there is a lot of salt on the road
I can certainly understand that you don't want to paint them but I believe it's the only solution when they're that far gone. Buy a Duplicolor caliper paint kit. It's amazingly easy.
1 Post
They get pitted, rusted and corroded if not painted.
Just clean them off, and paint them silver with the high-temp caliper paint if you want to keep the OEM look.
That's pretty much your only choice to get them looking good again.
Was that done DIY with the calipers on the vehicle? If so, was it spray on or brush-on?
I think the front caliper is pretty straigh froward howver I read somewhere that a VAG cable is needed for the rear. Is it possible to do it without the cable? Info will be appreciated.
