Carbon Build Up...Sell It?
#31
Very sad to see all the negative replies. If you love the Q you will keep it and do what you have to to maintain it. No other crossover is like the Q which, is why I chose it. I have 46,000 on my 09 3.2. If I need to do a carbon clean every 40-50k I am ok with that.
If you can afford to replace your Q every 3 years go for it. The 09 Q is one of a kind and the newer years seem to have more rattling issues and I do not like servotronic steering either.
at last some review gives hope
#33
Keep your Audi performing as it should. By using TOP TIER fuels, you help avoid deposit buildup on your vehicle’s engine, which can affect performance. In addition, using the correct engine oil can help prevent costly repairs.
#34
It does help keep injectors clean, have to give it that. Unfortunately that's not the car's Achilles heel.
#35
Issue - Direct injection engines such as FSI get carbon buildup on the valves and injectors because there is no fuel passing over them as it does for other engine designs - so no cleaning. This leads to misfires, loss of HP (substantial) and potentially other issues for the engine.
A U.S. patent application filed in 2002 by Volkswagen AG explains the DI-engine carbon-deposit dilemma this way: “Gasoline engines with direct injection of the fuel into the combustion chamber…suffer especially from the problem of the formation of carbon deposits…especially in the neck region of the intake valves.”
The document describes these deposits as a sticky coating of oil and fuel constituents that, once formed, serves as a base for further deposits, creating “a circular process, by which the coating thickness of the carbon deposits continuously increases.” Excessive carbon deposits “have extremely negative effects,” the patent application concludes, citing significant performance losses, sporadic ignition failures and, potentially, holes burned in the structure of the catalytic converter (should bits of carbon break from the valves and pass though the combustion chamber).
-Dennis
#36
#37
I also had Audi Q5 3.2 (2010) as is nearly 36k, been using it as my daily commute and to upstate NY every other weekends, still drives like new... and never disappointed me so far.....Maybe i am lucky? I think if you drive everyday and do your normal maintenance than it should be okay? am i right?...Thanks
#40
when your turbo charged you have to change your engine oil every 3500 to 4500. dont listen to anyone at the dealers telling you to change your oil every 10k miles. my dealer changes my oil every 4500 miles on my 2012 2.0T Q5. My friends are boosted and they need to change their oil every 3500 to avoid carbon build up. And we are talking about 400HP to 500HP turbo charged engines which has carbon build up like theres no tomorrow. 10k on a non boosted car is fine.
