Cheap Sim Card and Plan for Audi Connect
#301
Just followed Starfish63's advice for Freedom Pop and works a treat! Thanks
https://www.audiworld.com/forums/q5-.../#post24990689
#302
How is everyone's data usage looking like? And what all do you do to get that?
I used 87MB just in 1 day, about 1.5 commute total using google earth as the map.
I used the google search function once.
#303
The Google Earth overlay will use quite a bit when first caching your local area. If you stay within about a 20 mile radius, the data draw will be minimal. Once you leave that area, the cache will be overwritten with new data again. Earth can be a real data hog.
#304
My FreedomPop account "went dormant" due to lack of use in a while. I hadn't needed nav help and wasn't using google earth. I found out it was offline when I actually needed help finding an online destination. Not there when I needed it, lol. Anyway, all you need to do if this happens to you is log into FreedomPop and click a button.
#305
I think I've used up my MB which is why the Google maps stopped along with online search capability. I have a Freedompop SIM. Trying to reach these people to get either more MB or on a plan is nothing but frustrating. They won't answer my questions and I've called three times. Each time they transfer me to a support queue where I have to pay $5 to talk to someone. The website is completely unhelpful. Here I am trying to give them money and they put me into an endless circle. I'm done with Freedompop.
#306
You should be able to do everything on the website... If you set Automatic Top-up, once you use the 200MB, it will charge you for whatever you use over that. I rarely go over 200MB, so that's the best for me. Your milage may vary...
Note: My Global SIM stopped working not long after I got my LTE SIM, so I had to switch SIMs. If you have a Global SIM, you might need to replace it.
From account Overview page
- Manage Settings
- Credit Balance
- Enable Automatic Top-up
#307
- Manage Settings
- Credit Balance
#308
Thanks
Just got my FreedomPop 3in1 LTE card in the Mail today. After 5min of research on this thread, I got it up and running in my 2014 A6. Used the attz APN mentioned below. Just thought I’d confirm that the FreedomPop method still work and to say thanks for a great (and free) solution.
Eric
Eric
#309
Just got my new '18 S5 sportback and currently in AudiConnect Trial.
I think there are really two things here; the AudiConnect for all the online services the MMI does. I think for that there is no option other than AudiConnect service via AT&T. I don't think there is any way around that even with another SIM card. Correct?
The other thing is the wifi hotspot, which I think would work if the SIM slot is supported (think it might not be in the newer cars)
#310
Once AudiConnect is working with your trial period or paid service, it will work with any SIM. I have used 4 SIMs since my trial ended. All work with AudiConnect.
The WiFi hotspot is simply a WAP (wireless access point) for the vehicle's network. If there's no active Internet connection, then it's Intranet (local) only...
