Cigaretter lighter sockets not working
Both front cigarette light sockets in the front row are not working(just below the HVAC control and one in the center console box). I checked the fuse in the trunk right hand side and they are okay, all four 15A fuse are intact.
Where can I check next to get the power back to the outlets?
tonyq8330 (03-07-2020)
Production Solution
Optmized convenience system control (convenience/comfort) 046 module (J393) software.
how did you check???
not all usb charge sockets 5V output are compatible. Had to change mine to a different make. The one I have now is made in USA bcs those made in China had wrong dimensions and did not sit properly. This just in case.
Did you use a multimeter???
if you did then we need to check fuses diagram too..
See post below. Luggage compartment fuse.
Best of luck.
Best of luck.
Fuse diagrams
Alex Srbljan
9
10-25-2016 07:54 AM
TheMidnightSun
04-18-2005 08:44 AM
