Leaky 3.2 engine
Leaky 3.2 engine
Hi,
For a few months I have my engine that leaks some coolant fluid. Not much but enough for me to add some replacement coolant every two weeks to keep it a the minimum level.
I changed the thermostat becaus I tought it was leaking from there but it looks like it is leaking from the part circled in red (see picture).
Is there a procedure that exists to change it? What is that part (number?) I can't find it anywhere.
Thank you for your help!
Martin
It’s described as a water inlet tube or maybe outlet tube. It’s been superseded so maybe it was improved.
06E121168
It’s only like $30-40.
06E121168
Great!
Thanks for the info. However I hope I can replace it without removing the front of the car!
There is not a lot of space between the engine and the radiator!
Cheers
Martin
Cheers
Martin
Does anyone has access to a procedure for replacing this water inlet tube?
Do I have to remove the radiator to get access?
M.
M.
Martin having done many "remove the front of the car" repairs, it's nowhere near as bad as it's often made out to be.1/2 hr once you've done it a few times.Once you've yanked the nose it gives you clear access to the front of the engine.Rad and condenser "hinge" off to the side without having to drain fluid or remove gas.It's a good system.
Audi S4-GASM
05-28-2008 11:17 AM
"check engine light on", "check engine light off", "check engine light on", "check engine light off"
rdynamix
05-10-2005 12:23 PM
Eric 2.7
03-20-2005 07:25 AM
Stu B
08-13-2000 09:56 PM
