Q5 Nav add-on later?
So, I searched the forum first, but didn't find an answer to this. If you have a Q5 with the current MMI (the convenience package), it is possible to retrofit Nav?
On top of getting the MMI unit there's also a center console control panel and color driver info panel not to mention it now comes with backup camera and parking assist.
Im sure if you really wanted to and had the time or $$$$ you could do just about anything but by the time you add up the cost of the components and professional install the cost would be the same if not more then getting the factory installed package.
I've been using the aftermarket, non-factory solution with touchscreen added. It also has rear camera which looks factory and has a myriad of media playback options. It also came with maps for the GPS software which is installed on a SD card. I assume the maps and GPS software can be updated easily. I've personally tried the factory NAV but didn't think it's worth the 3k for the package. The aftermarket one costs a lot less and, in my opinion, is far easier to use using touchscreen inputs.
farsed
Q5/SQ5 MKI (8R) Discussion
06-28-2013 06:36 PM
Q5newb
05-13-2012 06:04 PM
stanw
30
03-05-2012 02:41 AM
ELHover
A4 (B7 Platform) Discussion
11
08-20-2007 12:59 PM
Er-excess-4
9
02-25-2004 04:05 PM
a5, add, added, adding, aftermarket, audi, br, convenience, nav, navagation, navigation, package, q5, software, system
