Replacing Rear Footwell OEM Lights with Brighter LEDs
#11
If anybody is having issues removing the rear footwell light assembly, it's actually super simple. I broke one light before figuring this out:
Move seat all the way forward and raise it all the way up.
Now you can stick your head beneath the seat and find the big circular hole right next to the footwell light. It helps to have your cellphone flashlight handy to see better.
Put two fingers through the hole and place them on top of the light assembly -- now push down to pop it out. You may or may not need to loosen the light first to pop it out. Use a metal flathead screwdriver, not a nylon trim tool for these rear lights. Once popped out, use the flathead to disconnect the light by pressing in on the retaining tab.
Hope this helps someone!
#12
To the OP, do you find the footwell lights too bright? I bought the full LED kit and have swapped out everything except for the footwells as I'm concerned they will be too bright when driving at night.
#13
Did you enable the ambient footwell light coding??
#14
If you can control OEM with MMI our LEDs will also be dimmable no issues.
Or you can go with our color changer model that has a built in dimmer in the remote.
Check them all out here:
Footwell LED Difference for all Audi Models | deAutoLED
w:http://deAutoKey.com
-Error Free LEDs for your Audi (interior & exterior)
f: https://www.facebook.com/deAutoKey
i: http://instagram.com/deAutoLED
#16
NICE
#18
This is from the Q5 footwell led light retrofit guide: (which I have obviously, as I said I am not following others work but doing it differently).
’09 – Central Elec.’
Coding
Long Code Helper
Byte 16
Activate Bit 6: ‘Interior/Ambience lighting adaption active’ first, by clicking on the tick box.
Then, activate Bit 0 ‘Footwell lights front installed’
Come out of the ‘Long Code Helper’ by clicking on ‘Exit’ and then ‘Do it!’
To enable the Screen Menu on RADIO CONCERT
[56 - Radio]
[Coding - 07] -> Long Coding Helper -> Byte 8 Bit 7 - Interior Light Settings active - (1 = active)
If you dont have radio concert you need to check how this is done with your mmi.
Footwell lights should be on and you should be able to adjust the light level in your MMI.
Coding
Long Code Helper
Byte 16
[56 - Radio]
deAutoLED.com
S4 (B8 Platform) Discussion
74
10-29-2022 11:02 AM
deAutoLED.com
156
09-16-2021 11:44 PM
deAutoLED.com
93
09-02-2021 08:15 AM
Audi Q5 2016 Audi SQ5 Premium Plus
a4amg
05-22-2016 10:07 AM
